Door seal is missing!
Old 03-21-2010, 08:53 AM
evilZO6's Avatar
Default Door seal is missing!
My car is missing the piece that the wires feed through to move from the engine compartment through the door. Its that little flexible rubber sleeve. I had it, lol, but lost it when i took my door off. Im nervous to drive my car or get it wet without it because i had to replace the door harness, and thats where the cut was made! Even if i were to buy one off a wrecked car, its a ton of work to get to it! So i was thinking, is there something i can buy at say the hardware store? i can just cut it, and use silicone adhesive to glue it down and make it water tight right? Thoughts? Comments? Similar situations you can share stories and solutions about?
