Rear end id
Old 03-26-2010, 01:21 PM
tbarnard2's Avatar
Default Rear end id
How do you identify a stock f body rear end. I know its a 10 bolt and i know it is from a 98-02 with four channel abs
Old 03-26-2010, 03:29 PM
BOA279's Avatar
then there you have it....stock rear end. What else do you want to know about it? Are you trying to locate one out of a car in the junk yard or something?
Old 03-26-2010, 05:06 PM
tbarnard2's Avatar
Auburn or torsen
gear ratio
limited slip or posi
Old 03-26-2010, 05:10 PM
tbarnard2's Avatar
I just placed it on jack stands and removed the cover its a 3 series, auburn, with either 3.23 or 3.42 gears
i used the rotate the yoke aand see how many turns the wheel rotates..
I picked it up from a junkyard for 350.00
the donor car was a 99 trans am with 23799 miles on it....
Very clean, not Broken in yet
