Storing a LS motor?
Old 04-04-2010, 08:12 PM
DamianN.'s Avatar
Default Storing a LS motor?
I am currently doing a complete rebuild on a LS1 with all new parts, it is getting clean and honed this week. I will be leaving for Cali mid May for 10 weeks. The motor will be sitting around and wondering what I need to do to keep it good. When I get back it will be going in the car and broke in.
I want to assemble the short block and Put a thick trash bag around it and vacuum seal it. Cause I don't want to leave everything laying around.
-Will it be ok as long as i kept the sleeves/mains lubed with oil or WD-40?
-Will it be ok with fresh bearings and assembly lubricant?
-Should I just leave it apart and build it when I get back? (really don't want too)
Any advice would help.
Thanks,
Damian
Old 04-04-2010, 08:15 PM
colt_impala's Avatar
theres a sticky for this somewhere i just cant remember where. im leaving april 21 for ft. Sill, OK for 15 weeks.
Old 04-04-2010, 11:38 PM
DamianN.'s Avatar
hmm cant find it
Old 04-05-2010, 10:07 AM
Pocket's Avatar
Oiling the cyl walls and using a trash bag should be enough. Id use oil instead of WD-40. Assembly lube will be fine on the bearings. 10 weeks is no real sitting span for an engine
Old 04-05-2010, 11:28 AM
DamianN.'s Avatar
thanks :-) just want to double check.
Old 04-05-2010, 11:34 AM
this is the sticky i was thinking of. its not exactly related to your issue but close.
