AC line filter
AC line filter
I'm in the process of replacing my compressor and noticed there is a small filter in one of the ac lines. Does anyone know where I can get a new one as mine has some metal shavings in it? Part number? Or do you have to order an entire new line that it comes in? Thanks for the help.
P.S. I tried search and it yeilded nothing
If you see metal shavings in your orifice tube, you need to more than replace just that. It's time to have the whole system properly flushed, or the next thing you'll be replacing will be that brand new compressor.
metal shavings is from the air compressor. definetly shot. I cant remember witch line it is in, but you will see little crimp marks in the line to indicate where it is, the crimps are to keep it in place without getting sucked in through the rest of the lines. the old will will just pull out and the new one just presses in.
