Water Pump
Water Pump
So after owning my 02 WS6 for a week, the water pump is leaking like a **** and obviously needs to be replaced. Smells like coolant bad after I drive it for a bit. So do I replace it with a OEM pump or do I upgrade to an Electric? Not a DD but I want something reliable.
Well I actually can't be a 100% sure it's the pump. I jumped to conclusion. I've actually got it scheduled for a pressure test tomorrow. The car only has 27k original miles on it so I find it hard to believe it's the pump already....but then again anything is possible. So if this is a common issue with the gaskets, is there a better gasket avail for these over the one it comes stock with?
