what maintennance to do with new car
I just bought a 2001 SS automatic convertible with 15,000 miles and was wondering if anything needed to be done maintennance wise to a car that is 9 years old and has so few miles. Car was driven, but not much. I have already changed oil and filter and will be draining/ flushing coolant this weekend. Anything else recommended?
If it was me I would change all the fluids. like tranny fluid, brake fluid, power steering fluid. All this is relatively inexpensive and good to get clean fresh fluid in.
yeah, i thought about that. tranny and brake fluid I'll probably do. Don't think rear grease would have any issues just from sitting. thanks for reply. anymore suggestions from anyone?
okay. i've changed engine oil, in the process of flushing coolant, and I'll try to get fuel filter done this week. Air filter is a new K&N. I'll do brake fluid flush soon as well. I think I'll wait a little on tranny fluid. May install new converter and then I can do full tranny change at that time.
If I were you I would clean the K&N they usually over oil them from the factory. For the trans fluid just drop the pan and change the filter. Also your rear end gear oil probably needs attention. Get a Fel Pro gasket and take the cover off. Let it drain, clean it out really good inside, put the cover back on with the gasket dry, add a jig of limited slip additive, and fill with GL-5.
thx
You can flow air, or you can get the dirt out of it. They don't both happen at the same time.
And you really wasted your money on that K&N air filter.....all they do is damage your engine, keeps the MAF dirty with a film of the K&N oil which gradually over days, weeks and months...covers the MAF sensors with a thin coating and decreases your perfomance, and its a pain in the *** to have to clean, re-oil, let dry, etc.....
A paper filter BLOWS the K&N away for engine protection........and there is no way on gods green earth that the K&N will make the car perform any better, its total horseshit.
There's a TON of hilarious, garbage products out there......ask before you buy anything.
No need to slam me on the K&N. It came with the car. Previous owner just put it in car. It has less than 500 miles on it and still looks brand new. I'm not a complete idiot, just new to the LS1's, so I asked you guys for opinions on what you thought would be needed. I'm a Mopar dude, but they haven't made a V8 convertible that working class people can afford since the 70's. Would love to have a 'Cuda, but no chance of that. It will be a while on the converter, so I am going to do tranny fluid asap. Thanks to all those that have replied.
LS6427-I was thinking about getting a Tornado and Hypertech tuner, and wanted to ask you before I bought anything.
The Tornado...I've only heard good things.
As far as maintenence, you should also change your belts. They go bad just from age, and if you lose the main drive belt, you're stranded.
No problem guys. I intend to do all the fluids changes. Just have to get time to do it. I guess the first post did sound like a newbie. I was basically seeing if there was anything specifically with these cars that needed attention that I wasn't aware of since I am new to these cars. I notice right of the bat that the cars are very noisy. I know the LS engines are noisy, but the car also has alot of interior squeaks and rattles. I ordered SFC's to try to help with some of this. Also, rear suspension bushings make alot of noise until car is driven a few miles. Thanks for the advice.
