Factory electronic antenna won't go down...
So I noticed yesterday that my antenna in my 98 Formula didn't come down after I turned the car off. After turning it on, it didn't go down or up, its just stuck in the up position?
Any ideas? Hopefully this is an easy do it yourself fix.
I can hear the motor trying to work (although the noise it makes is not normal), but the antenna just stays up.
I sprayed a little WD-40 down the antenna thinking it might help if something was gummed up, but it still is the same. It won't push down with normal effort (I didn't want to try to force it).
Anyone?
Anyone?
Save the manuals!
https://ls1tech.com/forums/stereo-el...enna-dead.html
BTW - WD-40 is a bad thing for many things. If it got down in the antenna mechanism, it could dissolve all of the good lubricants around the motor gear. WD-40 is great for loosening rusted bolts and waterproofing the outside of missiles, (or whatever it was invented for) but that's about it.
My 98 T/A did the same thing two weeks ago. I purchased an OEM replacement off of ebay for $35 . Havent installed it yet, cause Im trying to get a rear end for it as well. IT came with everything to install. Just another idea.
Both of my Firebirds have had power antenna issues. The V6 firebird that I had before had an antenna that worked for a while, but then it took a crap. I never got around to fixing it before I sold it, so I just raised it all the way up then disconnected the power to the motor.
My 2000 Formula has had the same problem since I bought it last year, and actually came with the motor disconnected. One of these days I might get around to fixing it, but I've got bigger fish to fry right now.
Does anyone know if you have to run a new cable from the antenna to the radio when you replace the antenna assembly? I would imagine that is a PITA if you do.
Mine officially took a sht last year, and wont raise when the radio powers on. Haven't changed it yet since I still get good reception of the local stations I listen to. Autozone has a replacement for $55, and the part number is AW-PW22.
-Joel
-Joel
