turn signal flashers location
Old 04-20-2010, 02:16 PM
conde'strans's Avatar
Default turn signal flashers location
So I bought aftermarket LEDs for the daylights/turn signals and I need to replace the turn signal flashers for aftermarket ones but I can't find where the damn flashers are. Can anybody help me and tell where they are? I was told they're under the steering wheel and I'm looking under there but can't find them. I was told they look like a relay but round instead of squared.
Old 04-20-2010, 10:07 PM
peterlawl84's Avatar
You are looking in the right place, but its hard to see bc its clipped on the back side of the brace, so you can only see the metal clip. It should be located along the passenger side under there...sorry I don't have a pic of the location, but the flasher unit will look something like the pic attached. Like I said though, you are looking for the metal clip holding it, the actual flasher unit is on the backside.
The following users liked this post:
k3000 (03-24-2021)
Old 04-20-2010, 10:34 PM
frogger13's Avatar
Take the kick panel off,lay on your back and look behind the ac/heater controls.
It helps to turn on your turn signals on to hear it, if it still works..
Old 04-21-2010, 02:58 PM
I found the hazards flasher yesterday afternoon thinking that was the one for turn signals and then gave up kinda frustrated that they wouldn't work but now I have to look on the right side neard the AC controls. Thanks guys I was frustrated as hell yesterday trying to find the damn thing!
Old 04-22-2010, 10:48 PM
frogger13's Avatar
Its on the driver side behind the ac controls.
I went through the same thing!!!
Old 04-22-2010, 10:53 PM
frogger13's Avatar
https://ls1tech.com/forums/general-m...l-flasher.html
Quick Reply: turn signal flashers location
