Thermostat Question
Old 04-22-2010, 03:50 PM
Bad Notch's Avatar
Default Thermostat Question
2000 WS6
I know these cars run good with some heat in them, should I put a cooler thermostat in my car while the motor is apart for a cam install ? Im thinking like a 180* stat assembly or do I keep the stock stat and bring the fans in sooner ? If I get a new stat, where is the best place to get it ?
Old 04-22-2010, 03:57 PM
fleetmgr's Avatar
If you want a new stat, any parts store has them. But there really isn't a great reason for going with a colder one, you won't feel the miniscule power increase but you might see it on a dyno.
Old 04-22-2010, 05:40 PM
jcobra99's Avatar
Lower coolant temps is always a good thing. Get the 160 they run about $50 for the entire assembly. The 180 wouldn't be much of a difference to be worth it IMO.
Old 04-22-2010, 06:17 PM
S2K
S2K's Avatar
Location: Bristol, TN/Knoxville, TN/Mooresville, NC/Phoenix, AZ
I thought stock was 180?
Old 04-22-2010, 07:18 PM
sjsingle1's Avatar
x2 ........
Old 04-22-2010, 07:37 PM
Bad Notch's Avatar
ok, thanks guys.
Old 04-22-2010, 07:57 PM
sjsingle1's Avatar
BTW.......i have the 160.......not a problem
Old 04-22-2010, 09:03 PM
vtirocz's Avatar
I disagree that lower coolant temps are always a good thing. The stock thermostat is designed to keep oil temps hot enough to burn off condensation. This is one of the reasons OEM thermostats are generally around 190-200F.
In my opinion, the dissadvantages outweigh any advantages of the colder stat.
Old 04-22-2010, 10:02 PM
98ZEMT's Avatar
I have a 160 and have had no problems at all. Actually went with a stock replacement and ended up going back to a 160. Oil pressure dropped significantly and it just ran slower. I know it sounds crazy but I'm serious.
Old 04-22-2010, 10:46 PM
sjsingle1's Avatar
just because the T stat is 160............does not mean that the coolant temp will be 160............so dont worry about the engine being to "cold"
Old 04-23-2010, 03:01 PM
jcobra99's Avatar
It will still have plenty of heat to burn off condensation. Even though its a 160 thermostat your coolant temps will defiantly be somewhat higher that 160 especially during the blazing summer heat and stop and go traffic. I have been running my 160 hypertech without any issue.
Old 04-23-2010, 04:23 PM
S2K
S2K's Avatar
My two cents: I have a 160 in my car. If was to do it over again, I wouldn't change it out unless I was getting symptoms of it sticking/staying shut. I can see going ahead and doing it on a high mileage motor though, as if to avoid the problems I mentioned previously.... I would just install a manual fan switch or reprogram the fans to come one sooner.
Old 04-23-2010, 05:51 PM
THE SHOP's Avatar
Also the temp was designed for emissions also, your cooling capabilities are what really set your running temp but whatever.
