blinkers and steering
Old 04-29-2010, 04:24 PM
Reilly 00 Z28's Avatar
Default blinkers and steering
When I put my blinkers on one side doesn't blink. I believe this is because on of the bulbs is out. However this bulb keeps going out everytime i put a new one in. Could this be due to a bad body control module? And also after i complete a turn the blinker wont go off by itself is this an easy fix? (not a big deal but just aggravating)
My steering has play in it but it doesn't seem lose. There is a specific point where it starts to turn the wheels on both sides (almost like on tooth of a gear is missing). What could cause this and how do i fix it?
Old 04-30-2010, 06:47 AM
Save the manuals!
wssix99's Avatar
Its probably a cracked turn signal lens that's allowing water to get in. Water + Hot Bulb = Bad.
Is there water in the bottom of the lens?
Old 05-03-2010, 01:35 PM
i didn't see any water but there is a big hole. aka probably the problem.
Thank you
