Battery question
Battery question
Hi all, yesterday my battery took a crap and I was able to get a new one today, I took the old one out for the core charge and the car sat for about 2 hrs with no power.
I put the new batt in and fire the car up and it was running like I pulled 4 plug wires and stalled, it did this 3 times and then started to idle but as soon as I gave it some pedal it wanted to die again and did, fired it back up and it found its idle point so I let it run for about 5 min and shut it off.
my question(s), is the PCM going to have to re-learn everything, is this the norm for battery replacement, is something jacked up???
Thanks in advance for you suggestions and comments.
Bill
Bill
if it was without power or battery, it will have to "re-learn" but sounds like somthing is wrong... did you reverse polarity between positive and negative? if so you may have damaged the pcm... "re-learn" generally involves irratic idle, but never stalling.
Thanks for the reply but no I did not reverse polarity, I'm hoping it just needs to relearn the parameters, I'll find out here at 4:00am when I leave for work haha.
Your ok. It just needs to relearn everything and it takes a bit. Its probably having a hardtime finding idle at first, and when you give it gas, it goes up and then dips down and slowly comes back. Its totally normal, trust me.
Bill
Bill
Whats the latest, have you tried driving it at all? You may have a broken battery cable, that will cause stalling and rough idling.
A BIG Thank You to all that tried to help me diagnose the problem, great suggestions guys.
I've never expierienced this with any of my other cars so it had me kinda bugged.
All is well in Formula Land, she ran perfect this morning and on the way home too.
I'm chalking it up to having to relearn the idle etc.
Thanks again
Bill
Thanks again
Bill
