Help whats this sound!!??
Old 05-11-2010, 02:00 PM
BFarrier's Avatar
Default Help whats this sound!!??
This sound happens once the engine has been shut off for about 45 min to an hour and when the engine is some what warm. then after about a min or so it stops making the sound on its own. doesnt matter if a/c or heater is on/off. please help if you can!
http://www.youtube.com/watch?v=VUkVYij5R4A
Old 05-11-2010, 03:25 PM
fleetmgr's Avatar
Not trying to be a smartass, but I'd have to say "engine". That's the only thing I hear on your vid. Could just be my old ears, though.
Old 05-11-2010, 10:46 PM
WS6-R's Avatar
looks like the washer machine is running
Old 05-11-2010, 10:48 PM
WS6-R's Avatar
J/K
Looks like valvetrain not having enough lubrication at start up after sitting for awhile....
What oil are you using? weight?
I can hear it loud and clear.
Old 05-11-2010, 10:50 PM
LS6427's Avatar
Yeah, can't really hear anything odd......
Describe it.....
Old 05-12-2010, 01:05 AM
BFarrier's Avatar
i use amsoil 5-30w and the sound stops after the first little rev of the engine its kinda like a humming sound????... it goes away after the first rev then its just the sound of the engine.
Old 05-12-2010, 04:59 AM
myk
myk's Avatar
I'm sure I have the same sound that you do. I'm also convinced it's the A.I.R. pump doing its thing, as well as spinning its way into failure.
Wait...do you even have an A.I.R. pump?
Old 05-12-2010, 10:32 AM
WS6-R's Avatar
Thats a new one for me...AIR PUMP?!?!?
hhmmm....
Old 05-12-2010, 11:25 AM
Youshallgofo's Avatar
My car used to make that sound! People said it sounds like a spaceship. It's probably related to the AIR pump. Just rip that **** out and it'll go away. and how are you making 400hp with just bolt ons?
Old 05-12-2010, 11:53 AM
udienow's Avatar
I see the hose for the AIR pump in the vid... im going to assume he still has the pump also.
Unplug the pump and see if it still makes the noise. It can be reached via the access hatch under the car in the front driver side. 2 bolts hold the access hatch closed. Just know the SES will turn on if you leave it unplugged... but it wont hurt anything.
Old 05-12-2010, 01:19 PM
BFarrier's Avatar
its the SLP 400hp package on the car so the engine is rated at 400 not rwhp but im going to go with a 222/226 cam and the guys at EPS says i should have aroung 400 to 410rwhp after the swap so in about a month or two after i order and install il have it tuned on the dyno and post up the print out of the dyno..
