Noise from rear of the car
Old 05-11-2010, 04:53 PM
udienow's Avatar
Default Noise from rear of the car
Its hard to explain this noise but its not like a click or rattle or grind... kind of a howl almost. You can start to hear it at 30mph and gets easier to hear the faster you go. It doesn't matter if I am in gear or neutral, none or part throttle, turning or going straight, the noise is there when above 30mph. I'm pretty sure it is not the rear end since the noise seems to be coming from the rear passanger side wheel area... though im not 100% sure. Also I am sure it is not the common noise a rear end makes because I have been in other f-bodys and they do not sound like this. Any ideas what it could be that isnt the rear end?
Old 05-11-2010, 07:43 PM
fleetmgr's Avatar
What kind of shape are your rear tires in?
Old 05-11-2010, 10:08 PM
1 FMF's Avatar
rear brake pads/calipers,
parking brake shoe inside the rear rotor hat
not much else back there that isn't the rear end, other than wheel bearing on the end of the axle shaft and tires.
Old 05-12-2010, 09:10 AM
udienow's Avatar
It is not the tires or wheels. I put on a different set of wheels/tires and it still made the noise. But to answer ur question my tires are in good shape.
Im thinking wheel bearing... but would a bad wheel bearing make a howling-like noise?
Old 05-12-2010, 10:31 AM
fleetmgr's Avatar
It certainly can.
Old 08-09-2011, 04:23 PM
swavely's Avatar
could be ball bearings, axles, bearings tires or very possibley your rear rears in the camaro dont last long i replaced mine twice know! and if its a axle bearing dont fix that just get another rear posi would be nice and through it under there changing axle bearings is a pain in the ***...
