Front turn signals
Front turn signals
Aye guys I am having a problem on both sides the sockets where the bulbs go are burning up, the bulbs are the normal 1157. The bulbs are melting to. Now they don't work cause the bulbs wont stay in. Anybody know whats causing this?
Save the manuals!
Yea, you need to check to make sure the housing isn't cracked. They take a beating from road debris and stones.
If you press on the outside of the lens with your finger, that should expose any cracks that might be there. Unless you are driving through swamps, a cracked lens would be the most likely source of large amounts of water.
Go here and you see what you need to do to fix them both for under $20.00. Very easy to do.
https://ls1tech.com/forums/general-m...ht=blinker+fix
Actually you can take the sockets apart and just swap over the new pins and plastics. No splicing required.
Nope, no good that way either. The Camaros have the sockets from the top and the heat from the bulbs cooks the sockets. They get all black and brittle so when changing bulbs they break.
Of course I went and ordered the sockets from advance 75 bucks later. I might see if i can return them and then buy the cheap ones. Do I have to get the housings at GM or will other places have them?
If you look on the sides of the socket, there are a couple little clips. Push those in, the center plastic piece slides out. The contacts plug into a connector on the wires, then the wires can pull out. Slide the wires into the new housing, plug in the new contacts, and slide in the new center plastic. Don't get the wires mixed up.
It'll make more sense when you take it apart. If you want I can get pics of the process in a bit.
Totally agree with you.
