Battery gauge acting weird and lights dimming and coming back
Old 05-29-2010, 11:52 PM
crazyelf's Avatar
Default Battery gauge acting weird and lights dimming and coming back
tonight after work i noticed when i started my car that the needle on the battery gauge was moving back and forth a lot and the dash and headlights were dimming slightly and then getting brighter repeatedly. the lights never got super dim but you could definitely see them fluctuating. It did this for about 5-8 minutes and then it seemed to level out and stop! no ses lights or anything and the needle never dipped into red zone.
I did use search but wasnt having any luck
any help would be great im suppose to drive to cali tomorrow!
Old 05-30-2010, 04:30 AM
BOA279's Avatar
make sure your belt is tight and not worn...but most likely its a failing voltage regulator.
Old 06-01-2010, 11:12 AM
LS1MONSTER's Avatar
Double check your battery posts and make sure the - & + battery cables are good and tight.
Old 06-05-2010, 01:54 PM
BFarrier's Avatar
my old 99 did that and it ended up for me being an altenator untill the whole thing went out about 2 hours of driving after i noticed the lights fluctuating then everything died
Old 06-05-2010, 07:08 PM
fleetmgr's Avatar
One or more of the diodes in the voltage regulator is failing. Time for a new alternator.
Old 06-06-2010, 02:01 AM
bamalt1's Avatar
When mine did that, it was the battery terminals being too loose.
Quick Reply: Battery gauge acting weird and lights dimming and coming back
