Replacing Cats on 99TA
Old 06-02-2010, 11:45 AM
CubanGT's Avatar
Default Replacing Cats on 99TA
I need to change out the cats on the car to pass emissions. Well from the last time we had it checked, the cats were throwing the check engine light on. i havent been under the car to check them out, but wanted to ask since the exhaust is still stock, are the cats something that i can remove and install myself? or will i need to take the car to a shop? I mean are they bolt on or welded on?
Old 06-02-2010, 03:39 PM
blk/slvr02ss's Avatar
They are bolted & welded on.If u buy factory ones they just bolt on but they are not cheap unless u get a low mileage set from someone who took there off which is your best bet and i just threw away a set w/ 28,000 miles.
Old 06-02-2010, 04:05 PM
CubanGT's Avatar
So unless i have welding equip or a friend with some, not something that can be done at home on a weekend afternoon.. oh well, thanks for the info... ill def be getting under the car soon to check a few more things before i finally try starting it..
Old 06-02-2010, 04:21 PM
Yes,unless u replace them w/factory u need a welder.
