weird squeaking noise
Old 06-10-2010, 02:00 AM
99ls1fbody's Avatar
Default weird squeaking noise
hey guys
yea so i have searched the website and cannot find anoything...ok so i hear a weird squeaking noise when i turn left at moderate speeds and it will happen under hard turns and soft turns what could it be??? my car is lowered with eibach pro kit and stock shocks i also have 18" whells but it didnt look like it was hitting the fender maybe the inside plastic piece?? any ideas??
Old 06-10-2010, 10:23 AM
svendiesel's Avatar
Could be the spring rubbing weirdly where its seated. Does it sound like a grinding noise or creaking, or more like the noise you get when you rub your finger across like a piece of glass when its wet?
Old 06-10-2010, 11:16 AM
Drew24's Avatar
Is it coming from the front or the rear and have you done rotors and brakes recently?
Old 06-10-2010, 12:16 PM
svendiesel's Avatar
If its a high pitched squeal its most likely your brakes.
Old 06-10-2010, 12:24 PM
99ls1fbody's Avatar
i cant really tell i know its coming from the left side sometimes it sounds like the front and sometimes the back but it also doesnt happen everytime i take a turn..but i know i need rotors reaally bad in the back could it make the squeaking even though im not breaking??
Old 06-10-2010, 12:37 PM
KevinR's Avatar
Its kinda weird you posted this cause mine started making a high pitched squeaking noise this morning on the way to work. I got out of the car and pushed down on the front of the car and it sounded like the strut. Not sure yet, but I will look into it when I get home.
Old 06-10-2010, 01:00 PM
99ls1fbody's Avatar
yea but the weird thing is mine doesnt do it when i push down on the car
