always wont start on 1st attempt
i have a pontiac gto ls2 swap in my FD. everytime i crank it, it wont fire on the 1st attempt, i have to always go for a second crank, and then it fires. its bone stock with new spark plugs. any ideas? heres a video
http://www.youtube.com/watch?v=uuo57yox3sc
I had that same issue with my LS1 Z28 and it turned out to be the check valve in the fuel pump that went bad. it wouldn't keep pressure when the pump was off so when i cranked it over, it was dry of fuel. swapped out pumps and i was good to go. hope this helps
Josh
Josh
Yeah i agree but what you can do to check that is get a fuel pressure tester. They have them at autozone that you can rent for free. Turn in on in the aux position before you crank it and see what the fuel pressure is like. But it does sound like the fuel pump.
i just dealt witha car like this. i first though check valve in the fuel pump. to check it easy just let it sit overnight and push the valve in on the fuel rail and see if fuel sprays out. on the last car it ended up being the injector relay.
I dont know if this is it..but my T/A does the same and i put Bosch spark plugs in it..after that it dont start on first try. I keep being told its my starter..but its fine i think..had the same issue when someone put bosch on my formula..so perhaps its the plugs you put in?
