~~ Lag in accel, then none. Dont know how to explain... ~~
... Ill try my best.
When taking off under a good bit of peddle, I notice after about 2 ~ 4 seconds I gain a better pull.
Ill try again.
Say Im in 3rd gear at half peddle. Still acceling, but not changing from half peddle. About 2 ~ 4 seconds after this scenario, I can feel/get/seems like 20 more HP. It may happen at other times as well, might be this is the only time Ive noticed it because of how noticable it really is...
So... WTF?
Ill try again.
So... WTF?
If it is your injectors you can have them re-jetted. Not all places do it but there is a NAPA here that does them for around 30 bucks a piece I believe... they put bnew o-rings and seals and clean them out, then flow test them... but paying 30bucks or so a pop is alot cheaper than buying a new set.
Whatever it is, it sounds like something in the fuel system.
I want to mention this thread just incase it might be related
Is there anyway to tell if my injectors are going poop?
What I find strange is that its almost always the same scenario. Same pedal position, same acceleration, etc... I cant get it like that any other time...
Another thing I was thinking about: Could it possibly be my clutch? I know if I try to power brake or get on it hard Ill have a light clutch slippage, and I have the ever so common sticky pedal. My symptoms are not the same as others though, all I have to do is rev up the engine at a stand still and the pedal will **** up... My guess is that its slipping just a hair, and I mean just a hair (because it will still put me in my seat), and then it all of a sudden fully engages less the hair.
What do you guys think about that?
Moderator
made a HUGE difference in my car as i had a horrible stumble at part/light throttle@ 2500rpm
