whinning noise when turning
and how much diff fluid? also how do u change the rear diff fluid in these cars lol undo the bolts on the housing and then the fluid will drain out?
Unless you have a vacuum pump to pull through the check plug than yes you need to pull the rear diff cover for the fluid to drain out. You will need at least silicon to reseal the rear cover. As for fluid capacity alldata just specifies to the top of the fill hole i would imagine no more than 2 quarts.
