Vibration in the wheel!!
Old 06-24-2010, 09:19 PM
WS6 Rampage's Avatar
Location: The dirty taint of the country. ...Los Angeles
Question Vibration in the wheel!!
Random vibration in the wheel. Need some thoughts of what the issue is. The vibration in the steering wheel isn't limited to just the steering wheel. There is also a visual shutter in the wheels also. Only noticed while the car isn't moving. Noting noticable while car is in motion. Power steering fluid is at an appropriate level. No odd smells or sounds comming from the rack & pinion or pump. Steering wheel does not feel any more stiff than normal. Vibration isn't constant. It randomly pops in and out of vibrations while turning the steering wheel in both directions.
THOUGHTS?!
Old 06-26-2010, 03:23 PM
Bttt!
Old 06-26-2010, 04:45 PM
ULTIMATEORANGESS's Avatar
tires out of balance or wearing unevely perhaps.
Old 06-26-2010, 04:55 PM
Craig Gibbs's Avatar
im thinking tire rod.
Old 06-26-2010, 09:00 PM
doublea87's Avatar
check if the rack and pinion is tight and the bushings are good and in place
Old 06-27-2010, 03:28 AM
Tires only have 60 miles or so on them. Just did a motor build and threw the k-member and motor in last week. Maybe the alignment IS off.
Old 06-27-2010, 03:29 AM
Yea, already checked.
Old 07-04-2010, 02:52 PM
Bttt......
Old 07-07-2010, 02:20 AM
ls1 1990 VN's Avatar
Drive shaft!!!!!
