T-Top weather stripping
Old 06-25-2010, 04:11 AM
mrx8200's Avatar
Default T-Top weather stripping
I'm sure this has been asked a million times, but I have been unable to find an answer in my searching.
So the t tops on my car are starting to leak. The driver side is getting real bad. It's at the point where if I'm driving on the freeway in the rain I get a drip hitting me in the face every few seconds which gets real annoying in some hairy driving situations. I've found where I can buy weather stripping to change out the old ones, but I need to find a good write up of how to do it. Does anyone have a good write up on this? Does anyone know a place to get the weather stripping cheap?
For what it's worth the car is a 2002 Z28 (with t-tops )
Old 06-25-2010, 04:14 PM
CranMaro99's Avatar
I thought you were used to getting sprayed in the face every few seconds? Hehe couldn't help it!
Old 06-25-2010, 04:32 PM
mrx8200's Avatar
Not with water
Old 06-25-2010, 04:36 PM
2001NBMZ28's Avatar
My drivers side drips a little on the highway in heavy rain - done it since new. Before replacing weather stripping try wiping them down with some dialectric silicone grease, owners manual says it's regular maintenance, never do mine though.
Old 06-25-2010, 04:41 PM
mrx8200's Avatar
Sounds like a good thing to try before replacing the stripping. I'll check it out and see if it works.
Old 06-26-2010, 10:38 AM
Save the manuals!
wssix99's Avatar
This happens a lot. Another poster in another thread mentioned that they just adjusted the front of the T-Top socket so that it holds down tighter. I'm going to do this today to fix the same problem on my car.
In a really bad rain storm this week, I confirmed that the drips are coming in where the window, T-Top, and A pillar all meet. There is space between that weatherstripping, which goes away when the T-Top is pulled tighter.
Old 06-26-2010, 12:26 PM
CranMaro99's Avatar
Yeah John (OP) maybe we can try this out.
Old 06-26-2010, 04:18 PM
mrx8200's Avatar
How do you go about adjusting it? I'd really like to try this out seeing as the car is a DD and we get a little bit of rain around here.
Quick Reply: T-Top weather stripping
