A/C prob
A/C prob
The air works but only blows on feet and defrost, nothing comes out at the panel, even when I flip it to panel it still blows on feet and defrost. I started to take the controls out but I dont know what I am looking for. Thanks
That's the default mode when you lose vacuum. Check the vacuum lines from behind the intake going over to the passenger side near the PCM under the hood.
I just got finished fixing the same problem on my 07 trailblazer. It ended up being a electronic actuator that opens and closes when you switch from the upper and lower vents, not sure if the f-bodies have the same setup. I also have a quick question. I just recently put some fresh refrigerant in the camaro, but the A/C doesnt really blow that cold! Is this normal for f-bodies?
Yeah the low side pressure is good, the refrigerant I got from walmart, and I have no clue how to check the high side pressure. To give you a better idea of what's going on; the A/C works it's just not very cold.
OK, its def. vac. related. after doing some messing around. At idle when I turn the air or heat on the engine drops down to 500 or 600 til i turn it off then it goes back to about 1000. (I never noticed before because I was driving with the air on.) So I looked under the hood and didn't notice anything out of the ordinary? Any more suggestions?
I got it, the people who did some work on my car failed to hook up the vacuum line to the back of the intake, the reason I didnt get it right away is beacuse I didnt reach down far enough I was seriously less than half inch away from where it plugs in. Easy fix though
