Need some help with A/C parts
Old 06-27-2010, 08:02 PM
dcmercury2's Avatar
Default Need some help with A/C parts
Im sure this has been asked before but i need to replace the belt tensioner for the A/C system and both pulleys also. Does anyone know where to get these ive ordered parts online and they keep sending me the belt tensioner for the serpentine belt and have no idea where to get replacement a/c pulleys. i was thinking of pulling them and repacking to see if that would help the squel. Its for my 2000 camaro ss, and one more thing i got an a/c belt but its too long if anyone knows what the part number is for one that actually fits i would greatly appreciate it.
Old 06-27-2010, 09:35 PM
fleetmgr's Avatar
Any auto parts store will have what you need.
Old 06-28-2010, 01:04 AM
dcmercury2's Avatar
ive gone to autozone and they have no clue, ill see if i take the parts off and try to compare on the spot
Old 06-28-2010, 06:35 AM
fleetmgr's Avatar
try NAPA
Old 06-28-2010, 03:48 PM
buddyleex's Avatar
Do you have an aftermarket UD pulley?
Old 06-29-2010, 05:04 PM
dcmercury2's Avatar
yes i do, do you know what size belt i would need then for the a/c?
Old 06-29-2010, 06:57 PM
eseibel67's Avatar
A/C tensioner with pulley - Gates #38196
A/C idler pulley - Gates #36220
A/C drive belt - Gates #K040410
Any auto parts store can cross the numbers above and get them for you.
Old 07-03-2010, 12:55 PM
jgentry162's Avatar
Wink temp fix
If you need a temp belt noise fix. Don't buy belt dressing, a bar of soap works better than anything. Just rub the part of the belt that comes in contact with the pully with the soap bar put a thick layer of soap on it. When you crank it upafter around 30 seconds the belt noise will be gone, unless you have a real bad belt. This will keep it quiet a little over a week. Enough time if you have to order the belts.
