gas in oil, car won't start?
Old 06-29-2010, 11:13 AM
01wssick's Avatar
Default gas in oil, car won't start?
ok, new motor and everything. I put in 5w 30 break in oil (royal purple). before i did that the car would idle fine with 10w30. after i did the change and put in the other it started for a few seconds then stopped. will crank but wont start. smells like gas in the oil, I changed the oil and filter asap. any ideas? car still won't start. everything else is fine. spark plugs aren't wet.
Old 06-29-2010, 11:35 AM
01wssick's Avatar
all the grounds are tight on the cylinder heads and etc. I just don't understand why. I also bolted up my steering shaft.
Old 06-29-2010, 01:46 PM
fleetmgr's Avatar
Has nothing to do with gas in the oil. Something is either not hooked up, or not hooked up correctly.
