Coolant Leak
Coolant Leak
So I was on my way home tonight, and about halfway home I started smelling coolant. When I got home, temp was up to 210. I checked under the car, and found the leak, but I can't see where its coming from. Its not the water pump, cause I checked that. It seems to be leaking from somewhere near the harmonic balancer. Anyone have any idea what could be leaking down there?
Time to put it on ramps, start it up, and wait it out till you see where its coming from. And make sure you get it all the way up to operating temp. THEN, if you don't see a leak, shut it down and wait again, because the temp rises and the pressure rises for about 15-20 minutes after shutdown, maybe it'll leak then. But its probably your water pump thats leaking, or a water pump gasket. I know you said it didn't look like the pump, but when you have coolant anywhere under the water pump 9 times out of 10, its the weep hole.
well, I did another check tonight after work poured some more coolant in there. The weep hole is clean, but its definitely coming from the pump. It started leaking as soon an I poured it in there. Felt around, and I think its coming from the thermostat.
