A/c Compressor clutch not spinning ? system is empty
Old 07-05-2010, 05:28 PM
3800RS's Avatar
Default A/c Compressor clutch not spinning ? system is empty
my ac system has been empty from the swap. Trying to get it charged today. I noticed when i was adding oil to the system the compressor clutch wasnt spinning. Is that normal ?
Old 07-05-2010, 06:59 PM
slow's Avatar
yes, the pressure switch will keep the system off if there is no refrigerant.
Ryan
Old 07-05-2010, 07:03 PM
fleetmgr's Avatar
You'll probably need to jump the clutch straight to the battery in order to charge the system.
Old 07-06-2010, 06:59 AM
3800RS's Avatar
how do i do that ?
Old 07-06-2010, 09:15 AM
fleetmgr's Avatar
two pieces of wire, with alligator clips (go to Radio Shack). Unplug the compressor, attach a wire on each terminal on the compressor, attach the other end to each terminal on the battery. Doesn't matter which is pos and which is neg. Don't let the alligator clips touch each other on the compressor, or you'll get lots of sparks.
Old 07-06-2010, 09:26 AM
EDS01SS's Avatar
Or you can disconnect the connector from the low pressure switch on the drier and use a paperclip to jump the 2 terminals
Old 07-06-2010, 09:46 AM
slow's Avatar
since the f-car ls1 does not have a low pressure switch on the drier, I am unsure what you would jumper on the f-car ls1 system.
You can use the 2 jumper clip approach, or using tuning software or a tech2, just command the AC clutch relay on.
Ryan
Old 07-06-2010, 10:48 AM
3800RS's Avatar
low pressure switch on the orfice tube ? I believe its a 3 wire, 1 probably being the ground
Old 07-06-2010, 10:57 AM
fleetmgr's Avatar
No, switch on the upstream side of the orifice tube will be the HP transducer.
Old 07-06-2010, 11:00 AM
fleetmgr's Avatar
Ryan
True, but using the Tech2 or tuning software requires a whole lot more investment than 4 alligator clips and a dime's worth of wire.
Old 07-06-2010, 11:03 AM
slow's Avatar
Your approach is fine, and is much cheaper than the tech2 or tuning software.
The jumper the low pressure switch is not on these the f-cars, since there isjust a pressure transducer. Sure ford cars with the low pressure switch as mentioned on the drier is no problem to jumper with a paperclip.
Ryuan
Quick Reply: A/c Compressor clutch not spinning ? system is empty
