You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join LS1Tech.com today!
Just bought my second ls1. SUPER clean SS m6 with 79k miles for 7500. The car has a hesitation around 2-3k rpm where it just feels like it hits a wall! I bought it almost positive it was plugs, wires, fuel filter, or a bad coil.
I changed the plugs, wires and fuel filter. STILL runs like crap. I had it hooked up to a scanner at a local shop and there was a "slight" misfire on cylinders 2, 5, 6, and 7. NO CODES ARE SHOWING.
The car does not smoke and sounds totally normal.
Also this only happens under a load. In neutral it revs fine.
The shop said could be a crankshaft sensor or camshaft sensor.
ANY help would be greatly appreciated. THANK YOU!!!!
__________________
1999 Trans Am -------SOLD
1999 Silver Camaro SS: 444rwhp/439ftlbs Schwanke built 6.2L, LS3 Heads/Intake, Longtubes, TSP True Duals + Under Axle, NW92mm TB, 85mm MAF, LS7 Clutch, Pro 5.0, Lid, CTSV/Z06 Brakes-----SOLD
2012 Corvette Coupe CGM Auto ----------SOLD 2007 Victory Red Corvette Z06 2LZ
I fixed it. Mass Air Flow sensor just needed to be cleaned. Also cleaned intake. Runs like a champ.
GRAT !! Might as well going some tune up to it. air filter, plug , wire, fuel filter, rear diff, tranny oil, clean out the idle air control, TB. Not nessary to replace those now cause you still on low miles, but its worth to check it first.
__________________ 88 Iroc Z ( Slowly back into these type of cars again )
2002 Trans am red m6 T-top stock for now weekend crusing FIRST LS1 owner ( Havent update sig for 3+ years, its SOLD !
Yea I'm having the same issue but last week I got a P0506, I cleaned maf & TB, (IAC), & code went away. SOMETIMES I have to pump the gas 3 times atleast wen cranking the car then I have to press the gas @ 1k to let it warm up then a minute later warms up & the rpm drops to .5rpm, the car has egr deleted, rear o2 deleted, 8 month old front o2 sensors ngk 55 plugs. & missing 1 rear driverside header bolt (exhaust leak) car sat for 5 months, have msd 8.5 wires but not installed yet, I'm going to work on that header bolt today quick fix. Can anyone else help me ideas???
__________________ Modern Muscle 99 Camaro z346 Cammed|Stalled|Bolt Ons|Suspension
Quote:
Originally Posted by evangto87
if i were that 5.0 and saw the f body spinning while pulling away... i wouldnt want a rematch hahaha
Can you give me more info on about crank the car, first though in mine mind would be fuel pump. if you crank the car up and then shut it off, then crank it again, does it crank right away ? I need more info.
Yea it cranks after I shut it off but to turn it on again I gotta press the gas pedal several times again, after it starts it idles @ .5 it's got choppy sound
Mods are P&P tb, !egr, LT headers, 3inch y pipe, plugs ngk, car has 173k miles
Reason: Miles
Have you check the fuel pressure by hook up a pressure gauge to the back of the fuel rail ? sound like you have a leak some where, or your fuel pump is on it way out. but check the fuel pressure first, you can borrow the gauge from autozone.
or you can do now is pull the fuel rail with injector still attach on it, and prime the fuel pump, if you see any fuel coming out injector, you need replace that injector. Might as well get new set of oring for injector and make sure lube the new oring with light coat of engine oil before put back on the intake. but check the fuel pressure first, keep update here and tell us how it go.
Ok I'll check it today gotta change fuel filter & put on wires.
Wats fuel pressure its suppost b @
