Leak Where Oil Pan Meets Transmission
Old 07-14-2010, 01:24 PM
jason2687's Avatar
Default Leak Where Oil Pan Meets Transmission
I just noticed what I thought might have been a rear main seal leak or seepage. However, I wiped it clean and it hasn't shown anything in the last month.
Is it possible to leak clutch fluid just ONCE for whatever reason? Also, what could cause this to happen. I know with my old car, an overflow in the resevior caused clutch fluid to end up in the same spot under the car.
Old 07-16-2010, 12:36 AM
6.0 silverado's Avatar
Did you bleed the clutch recently? Maybe there was some left over fluid in bell housing.
Old 07-16-2010, 01:16 PM
jason2687's Avatar
No I didn't thats what is so weird about this. I know when I replaced the clutch on my previous car, there was the same run off in the same area the first day.
I haven't done anything on this car, so I'm not sure what to think.
