Need help finding ignition relay
Old 07-19-2010, 09:11 PM
Peweter2K2WS6's Avatar
Location: A little bit of everywhere thanks to Uncle Sam
Default Need help finding ignition relay
I believe my ignition relay has gone bad. I was having the typical symptoms of car starting some time and not starting other times. Now it won't start at all. I would like to replace the ignition relay to see if this remedies the problem. The only problem is when I look in the glove box, I can't find the darn relay!!! Any pics or write-ups would help. This has been nagging me for almost two years!!!
Old 07-19-2010, 10:21 PM
LS-1Z28's Avatar
the relay should be under the hood on the drivers side in one of the two fuse boxes... it is a large gray square relay you can't miss it.
Check your user manual if you can't find it.
