Turn Signal headache
Left front turn signal is not working and neither is the left front hazard. Rear left turn signal doesn't work , but the left rear hazard does work.The day time running light is functioning/working on the same bulb. What gives? I have already replaced the socket with the autozone 85881 socket and tried two different brand new bulbs. Any Ideas?
Got it whooped. The problem was the three factory connectors that plug into the socket. Clipped them off, and used butt connectors to splice in the autozone socket. I had attempted to install the old connectors into the new socket and they would not conduct, once I eliminated them, problem solved.
