bad EGR valve give bad gas miles ?
Old 07-22-2010, 11:56 PM
killagt's Avatar
Default bad EGR valve give bad gas miles ?
my check engine light on and show bad egr valve, we dont have emission here, so its ok to leave it out bad like that ? I dont want block it off or anything, does it effect engine performing or damage engine or gas miles ? thanks
Old 07-22-2010, 11:58 PM
Choppers's Avatar
They can give bad gas mileage. Why not block it off if you don't have emissions.
Old 07-23-2010, 12:07 AM
killagt's Avatar
if I block it off, what effect does it give ? does it still give bad gas miles if I block it off ?
Old 07-23-2010, 07:54 AM
fleetmgr's Avatar
EGR's have a diaphragm in them that eventually ruptures. When it does, the valve doesn't work, and you now have a vacuum leak. Either replace it, or block it. Also, be sure to check the vacuum line going to it first, make sure that the problem isn't in the vacuum line and not the valve itself.
Old 07-23-2010, 11:47 AM
killagt's Avatar
where can i buy a block off plate at ?
Old 07-23-2010, 12:50 PM
redbird555's Avatar
Most people just go buy a rubber freeze plug from autozone and stick it in the hole costs 8 bucks and works great. i cant remember the exact size tho
Old 07-23-2010, 06:23 PM
mwg2600's Avatar
Its an lt1... no rubber plug. You need a block off plate
Old 07-23-2010, 06:37 PM
killagt's Avatar
their is little vacum line to the EGR. what I need to use to block it ?
Old 07-23-2010, 08:21 PM
fleetmgr's Avatar
you can get rubber vacuum caps from any parts store, or you can take the low tech approach and stick a screw in the line. The cap looks better.
Old 07-23-2010, 08:24 PM
Formerly 99-2door-08/30/2010
PitchblackC3's Avatar
You can get the EGR delete plates on ebay for like $7. I just put some on a LT1 about a month ago.
Old 07-23-2010, 08:28 PM
killagt's Avatar
before I block it, any one pls tell me PRO and CON on doing this ?
Old 07-23-2010, 08:31 PM
fleetmgr's Avatar
Pro is you won't be recycling exhaust gas back through the cylinders. It's done to cool combustion temp to reduce NOx emissions. Con is, you won't pass smog....period.
Quick Reply: bad EGR valve give bad gas miles ?
