Strange problem that I accidently fixed... Any opinions? - LS1TECH
Thread Tools Search this Thread
Old 07-25-2010, 01:00 PM   #1
Slash8915's Avatar
Default Strange problem that I accidently fixed... Any opinions?
Ok, so I had a cam, stall, and gears installed about a week ago as well as a tune. Since then, my drivability has been somewhat lacking. As in when I'm going at low speeds, the RPM's keep trying to go up and I have to hold on the brakes to maintain a low speed (low as in 10mph or so). Also, if I were to rev it just a little, the rpm's would go up to about 1200 and just stay there, then SLOWLY go down.
I read on here it might be a vacuum leak, so I went out and decided to bypass my catch can. Well all hell broke loose. It would barely idle, then die every time I started it up. I also noticed that my miles driven had been reset to 0. So naturally, I put the hoses back on the catch can, same thing. I unplugged every plug from my air lid to my tb, then plugged them back in, same thing.
I was pretty frustrated by this point, so with the pcv hoses completely off of the catch can and not attached to anything, I started it, and wouldn't you know it, it started and idled fine. I turned it off, and attached the hoses to the catch can without the rubber gasket that goes between the top and the body, and it idled fine. I took it for a test drive, and the rpm's no longer tried to push through my brakes, and it drove just like stock.
I'm crossing my fingers that no other problems arise Since I only drove it about 1 mile. Any ideas as to HOW I managed to fix it, because I'm completely stumped...
Slash8915 is offline   Reply With Quote
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
