need help cant figure this one out, please help!!
Old 07-27-2010, 05:23 PM
RedLS1Iroc's Avatar
Default need help cant figure this one out, please help!!
this problem has been plaguing me for a while now. the motor runs great without a flaw until i get to operating temp then it bogs down and will die even sitting in place. if i give it gas while its bogging down it will backfire and die (almost sounds like a misfire) when i turn the switch off after it dies and restart it, it runs good for 10-15 minutes then the same thing happens again. i have recently replaced the battery, alt, fuel pump, water pump and thermostat and none of this has helped. im also not sure if i can have a diagnostic test ran being that the ls1 is in a third gen camaro, bought it that way and the wiring seems a little screwy. i have drove this car for over two years without a problem this just recently started happening and i have no idea how to fix it. any suggestion would be greatly appreciated.
Old 07-28-2010, 07:18 AM
Save the manuals!
wssix99's Avatar
Any codes? How are your O2 sensors?
Old 07-28-2010, 09:01 AM
RedLS1Iroc's Avatar
well i cant tell if it is throwing codes because im not sure how to check it being that the engine is in a 88 camaro.... with that said are the O2 sensors something i can clean to check or is it something that i would have to replace?
thanks
Old 07-28-2010, 05:11 PM
eseibel67's Avatar
Your car will likely have an LS1 computer and diagostic link, so you can get it scanned. That's how you can check your O2 action.
Old 07-29-2010, 01:29 AM
Save the manuals!
wssix99's Avatar
Sounds like an emissions function is causing your engine to go rich and choke. You'll need to commune with the computer to find out what's going on. Lot's of parts could be the issue.
Old 07-29-2010, 05:29 PM
RedLS1Iroc's Avatar
thanks for the help guys i guess i try and find somewhere to run the computer
