Rear Speed Senser
Rear Speed Senser
Ok, Has anyone had a speed sensor cause the car to feel like the trans is falling out.
The story is that the car had a code for the rear passanger speed sensor. After ordering the part I went for a cruise in the car and when I but my 4l60e into first it clanked and jerked. I was freaked out, called my shop and they said it was the trans. I got to thinking and the trans had no signes of being bad. Also it only did it in first gear when I started in first and turned to the right.
I unhooked the sensor and then the car seams to be fine!
Anyone else ever have anything like this?
The run down on the car is -
402 Ls2
DTS 12 bolt with detroit looker - felt like the locker was engaged
Bogarts with 28 inch MT Drag Radials
All New Bear Brakes and new axel bearings and seals!
402 Ls2
