Engine Coolant level Sensor?
Old 08-03-2010, 04:48 PM
allantransAm1998's Avatar
Default Engine Coolant level Sensor?
Can I remove the sensor without coolant leaking out? It's at the top right hand side of the radiator next to the battery? It looks like a square with a thread that foes into radiator
Old 08-03-2010, 04:52 PM
Packy's Avatar
No, fluid will leak out unless you drain it down below the sensor first from the drain plug that is on the bottom of the radiator directly beneath that sensor about 8 inches or so.
Old 08-03-2010, 05:25 PM
LS6427's Avatar
Just pull it out and let the coolant come out till it stops. Or if your quick it won't loose too much. I wouldn't mess with that petcock drain, those things break off all the time.
Old 08-04-2010, 03:17 PM
Save the manuals!
wssix99's Avatar
Or you can get a clean milk jug, siphon fluid out of the radiator till you are below the sensor and then pour it back in when you are done.
Old 08-04-2010, 03:39 PM
meine96ws6's Avatar
I agree..more work but less clean up..
Old 08-04-2010, 06:23 PM
IRONFIST's Avatar
Just pull the sensor, let it pour out, and replace after...
It's the least amount of work.
