Low Engine Power Light
Old 08-05-2010, 01:15 AM
firebirdmo's Avatar
Default Low Engine Power Light
So i was coming from work today in my 1999 Firebird and as i entered my neighborhood the "Low Eninge Power light" came on. Suddenly well as the light says, i lost power and regardless how hard i push the gas pedal, there was no response from the engine and the car wouldn't increase speed at all. I wanted to get some help as to what needs to be changed in-order to solve this problem. Thank you for all the help ahead of time.
Old 08-05-2010, 04:45 AM
vikingramair's Avatar
Do you refering to "reduced power mode" ?.
To narrow the rootcause you need to scan your car to find what faultcode is stored in the computer.
Old 08-05-2010, 05:17 PM
firebirdmo's Avatar
Ok. Yea that was the problem i was having and the light i saw.
Old 08-05-2010, 05:52 PM
arctic00ws6's Avatar
Is it an automatic? I'm not sure about firebirds but I know when my trans went on my 04 silverado doing some research i found that there was a safety setting that would put the transmission into a lower power mode "gimp mode" where u couldn't go over like 20 to ensure you got home and limit additional damage done to it, like I said not sure if it applies in this case but just something I dug up on the web regarding a GM. Sorry if wasn't any help but regardless I'd get it on a scanner asap to give you an idea good luck
Last edited by arctic00ws6; 08-06-2010 at 07:49 AM. Reason: On vacation trying to rush and type everything on my iPhone before she came back out, told her I wouldn't go on :x
Old 08-05-2010, 06:17 PM
firebirdmo's Avatar
Im going to check on the scanner..
Old 08-06-2010, 06:38 PM
Danny2tek's Avatar
lol at Artic's reason for editing his post
Old 08-07-2010, 01:48 AM
RedVertTA's Avatar
I second that.
Old 08-10-2010, 10:04 PM
firebirdmo's Avatar
I found out that i have a misfire on my 6 coil port, then my transmission needs the gears to be changed.
Quick Reply: Low Engine Power Light
