Leaking Oil Near the Pan!!!!
Hey guys, Ive got a slow leak coming from the passenger side of the oil pan. It leaks down behind the plastic shield beside the starter then drips off the bottom of the pan. It doesn't leak as bad when the front of the car is up in the air. When the car sits overnight it usually leaves a dime size spot on the carport slab. Anybody got any ideas or know where to start?
See image below.....
It might not be the same situation for you but i had the same problem with my ls1, i checked everything major to start with but come to find out there is a oil bypass valve that is held on the side of the oil pan on the passenger side with 2 10mm bolts. It was a 4 dollar gasket fix from gm dealer..
Well the good thing is when you buy a new rear main seal you get a new cover seal also BUT.... be very careful not to over tighten your bolts that go through the pan into the cover. I pulled my tranny got it rebuilt and replaced rear main and cover gasket but stripped my cover bolt threads installed tranny drove around to let it warm up. Had a bad leak. So I had to pull the tranny again the next day again and buy a new rear cover.put a little grunt into tightening them but not too much. Reinstalled tranny again and no leaks.
