Why Is My Engine Pinging???
02 SS with 48000 mi. ,every time I hammer down ,it starts pinging up in the higher RPMs and as soon as it changes gears (automatic).I use nothing but 93 octane and I drive it everyday.What does it need guys? Motor is all stock except for SLP lid.
Thanks
Larry
Thanks
Larry
I do use either BP,Shell ,or Chevron gas.Not throwing any codes.I'll try cleaning the Maf sensor tomorrow and see what happens.Thanks for the advice!
Low fuel pressure, dirty fuel filter, clogged injectors are a few things that will cause pinging. My 99 started to ping at WOT and I found the fuel system was toast, fuel pump rusted and fuel lines rusted. Injectors screens were clogged with rust. I'd check it over carefully.
