What are some cheep lt1 mods
Old 08-24-2010, 05:25 PM
94gt8er's Avatar
Default What are some cheep lt1 mods
Hi, Iv been wanting to gain some horsepower with out burning a hole in my pocket and was wanting some opinions on what i should get.Thanks
Old 08-24-2010, 06:27 PM
wysemunky's Avatar
nitrous
Old 08-25-2010, 10:14 AM
99monguse's Avatar
What model car do you have? need specs on car too.
Old 08-26-2010, 02:47 AM
94gt8er's Avatar
i have a stock 94 lt1 z28 camaro auto
Old 08-30-2010, 04:36 PM
SCULLYJR's Avatar
all the bolt ons
Old 08-31-2010, 12:13 PM
1998flamedCamaro's Avatar
Depends how big of a hole you want to burn.
My old LT1 was stock when I purchased it.
I installed a used moroso CAI ($75)
Used nitrous kit ($175)
J. Solomon tune (Cant remember but I think $100)
Tuning cable ($60)
colder plugs (~$20)
I also changed the plug wires, and cut out cat converter.
I ran a 13.3 on a 2.0 60' on a 75 shot. I sold the car before I could run the 125 shot at the track.
I say some sticky tires on the 125 would get mid 12's. But then you have to worry about the 10 bolt, etc.....
So in a nut shell I agree with wysemunky "NITROUS"
Old 08-31-2010, 12:24 PM
WSsick's Avatar
Same things you do to any car, open up the intake and exhaust. With an auto a stall and gears would wake it up nicely, but might be a little more than you want to spend.
BTW, wrong section. This should go in the LT1 forum, not general maintinence. Mods will probably move it soon.
Old 09-01-2010, 09:05 AM
99monguse's Avatar
Does your car allow you to manually shift into low1 (1st gear); some didn't...if they were 2.73 geared cars and didn't have the ZR tires. The very first thing to do is yank out the factory air filter box assembly...you may be able to sell it on EBAY, I don't know. Any of the cold air induction kits will work, I used a K&N CAI http://www.knfilters.com/search/prod...Prod=57-3010-1
This was worth every penny, huge difference on my 1995 Pontiac Formula. The I got a Hypertech reprogrammer http://www.summitracing.com/parts/HYP-30026/
With the reprogrammer, I adjusted the shift firmness and shift points, rev limiiter and removed the top speed limiter (my Formula had 2.73 gears and didn't have the ZR tires from the factory). I also tuned for higher octan fuel, turned the fans on earlier but couldn't do the highest setting tune because my thermostat was still stock.
These two mods dropped my car from a 14.4@95mph to 13.9 @101!
Now there are many other options out there besides K&N and Hypertech that will produce similar results, and possibly even better results being that I did this back in 1996.
A stall converter would be a huge improvement but you need other mods to go along with it: tune the computer, trans cooler, possibly a shift improver kit. The 4l60e trans in these cars is fairly weak in stock form and may not last too long with a stall but some do get lucky though. if you don't have the cash for a decent catback then just throw in a cutout in the intermediate pipe. Long tube headers and a GOOD y-pipe often net about 15-20 RWHP too.
Old 09-01-2010, 09:24 AM
WSsick's Avatar
.....or you can look at your RPO sticker (I think your year is in the glovebox, if not its on the inside of the door). If you find the code GU2, you have 2.73 gears; GU5 is 3.23 gears.
Quick Reply: What are some cheep lt1 mods
