Clunk when turning in reverse
Old 08-30-2010, 08:43 AM
cool whip's Avatar
Default Clunk when turning in reverse
When I'm turning in reverse I hear a clunking noise under the car. It's only when backing up and only when turning. When I back out of a parking space I hear the noise just before I'm ready to turn the wheel to shift into drive.
Edit: also wanted to note it doesn't matter if I'm turning right or left. Anything I could find searching didn't fit my situation exactly.
Old 09-02-2010, 08:50 AM
RedLed's Avatar
I have a 98 TA that does the same thing and I recently changed my brakes rotors shocks new tires and it still clunks! I dont know maybe a steering stabilizer shock?
Old 09-02-2010, 09:32 AM
killagt's Avatar
Your U joint is bad, get under the car and rotate the DS with hand, see how the clunk u talk about is their.
check your LCA too.
Old 09-02-2010, 09:54 AM
lefty2023's Avatar
i had the same thing you described and my drive shaft was bent.
Old 09-03-2010, 04:39 PM
RedLed's Avatar
lefty2023 just out of curiosity, how much was that drive shaft, parts and install?
Old 09-04-2010, 11:47 AM
antsls1's Avatar
i dunno my friends car did that same thing and it turned out being his rear end
Quick Reply: Clunk when turning in reverse
