New car , ASR BRAKE ABS lights are on .
Old 09-05-2010, 02:04 PM
randomnine7's Avatar
Default New car , ASR BRAKE ABS lights are on .
well i just picked this car up 01 z28 a4 . all stock except flowmaster and lid ..
on my first test drive of it it had a check engine light ( but its a bad cat)
lights for the ASR ebrake and abs all on .
the next day all the lights are gone . then last night they are on again ..
what could be setting off all 3 lights ??
i was thinking its coming from the rear as im getting a ebrake light even when its all the way down .
traction control sensor ? abs sensor ? maybe both ? all lights turn on at the same time when they do turn on .
wanna get this fixed . as its maybe the only flaw on the entire car
Old 09-05-2010, 08:52 PM
antsls1's Avatar
Sounds like a bad sensor somewhere but just curious what size wheels and tires are u running.
Old 09-06-2010, 10:13 AM
Save the manuals!
wssix99's Avatar
BTW - Your car isn't "new." You'll need to have the brake system scanned. The codes should tell you what's up.
Old 09-06-2010, 10:55 PM
its new to me ! lol,,
but stock snow flakes .
car will run for a good amount of time on nice streets with out the lights on but its done it twice were a bumpy road will set them off ..
im guessing its the rear abs or traction control button . or maybe even the ebrake sensor ??
Old 09-06-2010, 11:43 PM
Save the manuals!
wssix99's Avatar
probably a bad wheel speed sensor. definitely nothing related to the e-brake.
Old 09-07-2010, 06:37 PM
cleaned them out the lights went away . drove it a bit then came home parked it and when i turned it on again ligths were on ...
damn it ,,
where can i get these new sensors and does anyone have any other i deas on what it might if not the rear abs/speed sensors ?
Old 09-07-2010, 08:39 PM
Save the manuals!
wssix99's Avatar
Have the codes scanned. They will tell you what is going on.
Old 09-07-2010, 08:46 PM
antsls1's Avatar
Sounds like the last resort just became an only resort. Take it to a shop that can pull the codes around here it only costs 60 to put it on the machine. Hope its just as cheap for u.
Old 09-07-2010, 09:11 PM
Save the manuals!
wssix99's Avatar
Or if you are going to have the car for a while, you can invest in a scan tool.
Old 09-07-2010, 09:34 PM
Mike Morris's Avatar
Bet its a bad wheel sensor. With a scan it will tell you which one is bad...
gmpartsdirect.com if you want a replacement piece cheaper than your local stealership
Old 09-07-2010, 09:55 PM
Save the manuals!
wssix99's Avatar
My understanding that the brake light signifies a brake system malfunction - so there should be a code set, which should indicate where the problem is.
Old 09-07-2010, 10:50 PM
antsls1's Avatar
Yup u can pick one up at ur local Walmart for 135 now-a-days. Go figure yeah I said Walmart
Old 09-08-2010, 12:46 AM
a regular scan tool cannot read the codes . i need a tech3 or sumthing of that sort . my neighbor has both but the tech is lent out so im waiting on it ..
i did use his other to delete the ses light . and while i was using it the lights of the ASR BRAKE and ABS INOP were on and the scanner said all codes were clear ..
will check them out with the different scanner .
Old 09-08-2010, 09:54 AM
antsls1's Avatar
Oh yeah that's right. The TECHIII are just a bit more expensive lol. Lucky u no somebody with one I guess.
