Power Windows Not working Help with Electrical
Old 09-05-2010, 08:04 PM
Canada204's Avatar
Default Power Windows Not working Help with Electrical
94 Camaros Z28 My drivers power window doesnt go up or down the only thing I get when I press the button is a clicking noise under my dash is there a relay for the power windows that I could try to replace before I do the motor? I can only hear the click when the driver side is button is pressed.
Old 09-05-2010, 08:20 PM
antsls1's Avatar
Not too sure but it sounds like the automatic roll down has sshorted out. Pull ur door panel unplug the window motor and pull a volt reading. If nothing then trace the wires continuing to pull a voltmeter reading and when u get a reading of power it will be between the last place u cheecked and that point Where u have power. If u have ample power to the motor like around 12 volts or so it ur window motor. It could be a burnt wire or just a bad switch. Odds are its the motor or the switch.
Old 09-06-2010, 10:17 AM
Save the manuals!
wssix99's Avatar
Your motor is likely dead. The clicking for the driver's side is normal - its your express down module trying to work. When the motor is making noise, you don't normally hear it.
