Brake pad,caliper & rotor replacement
Old 09-11-2010, 06:55 PM
SHORTZ A KILLA's Avatar
Default Brake pad,caliper & rotor replacement
HI-Any stickys or tutorials on this site for above?-looking to do the job in my garage. Special tools, fluids etc. required? If not recommended books for "do-it your selfers."
Thanks in advance
Old 09-11-2010, 07:59 PM
Element's Avatar
Basic hand tools should suffice. Since you're replacing the calipers, you don't need a piston compressor.
Biggest thing is not to let the brake master cylinder run dry when replacing the calipers or bleeding the brakes.
Here's an install write-up on pads and rotors: http://www.installuniversity.com/ins...sity/index.htm
Old 09-11-2010, 08:37 PM
sjsingle1's Avatar
why the caliper rebuild?
Old 09-11-2010, 09:12 PM
Element's Avatar
Damn, my bad, I thought it went into detail on how to remove and reinstall the caliper.
