Engine squeal, not belt issue or PCV
Old 09-22-2010, 10:32 PM
onspeed's Avatar
Default Engine squeal, not belt issue or PCV
Reposting this in internal since general tech doesn't get as much traffic.
'00 Formula, 6speed, ~95k
About a month ago, my engine started to make a loud high pitched noise, sounding like a belt squeal. The noise stays the same pitch regardless of RPM, however when I put the engine under load, like 5th gear pull from 25mph, it will go away till I let off the gas. I removed both belts today, started the car briefly, noise is still there. Also, following the suggestion of another member, I tried pulling the oil dipstick with the car running to see if the noise goes away. No dice. Noise occurs regardless of engine temperature. Seems to be coming from the front.. or the engine at least.
Oil pressure is normal.
What's going on?
Old 09-23-2010, 10:10 AM
incbed's Avatar
The only thing I could think of is a small tiny intake gasket leak, or Tiny TB oring leak,,or the PVC valve is stuck making the air squeal.
Old 09-23-2010, 02:54 PM
RS777's Avatar
Do you have a gauge telling you oil pressure is normal? or does the car just seem fine?
Old 09-23-2010, 09:42 PM
defaultexistence's Avatar
crank hub/dampner loose
Old 09-24-2010, 04:34 AM
N2O-ARMD's Avatar
Could also be a lifter. They will squeal if the roller locks up.
Old 09-24-2010, 11:42 AM
onspeed's Avatar
Factory oil pressure gauge reads fine. Everything feels normal. Car pulls hard. Only issue is with the clutch.. either TOB going out, or air in the lines or something.
I've had a bunch of suggestions now, which is most likely? Remember, it sounds like a belt squeel, or maybe a high pitched whistle that doesn't change regardless of RPMs, but will go away when the engine is lugged.
Intake leak
vacuum leak
stuck lifter
crank hub/dampener loose
pcv valve
Old 09-30-2010, 06:12 PM
Gohard's Avatar
Does it sound like this? I had a shop change my tstat back to the stocker and put a new style pcv valve in and voila engine sounds like this
http://www.youtube.com/watch?v=3-ZbTeZXhug
Quick Reply: Engine squeal, not belt issue or PCV
