'98 Firebird overheating
Old 09-24-2010, 05:27 PM
lew10281's Avatar
Default '98 Firebird overheating
I dont know too much bout cars so this is whats happening. Got a brand new radiator put in and that kep it cool for a while. All of a sudden its running hot again. Went to get an Oil change and it was antifreeze in the oil.
What happens when i drive is it will start normal (about 180 degrees) then if im idle like sitting at a red light the temp will jump up to about 230 degrees (about the 3rd notch). Once i get moving again it will go back to 180 deg and fluctuate between 180 and 220 degrees. The mechanics i've talked to said its either a bad head gasket (i hope not) or a bad intake gasket.
Has anyone ever had this exact issue or possibly know what this kind of problem is? I hope its just a bad thermostat or water pump....anything other than head gasket
Old 09-24-2010, 05:34 PM
Ruthless909's Avatar
If you had antifreeze in your oil it is going to be a blown intake gasket, I believe.
Old 09-24-2010, 05:49 PM
lew10281's Avatar
About how much is that to fix?
Old 09-24-2010, 05:57 PM
Expect to pay over $1000 at a shop...
It'll be wayyy cheaper if you do it yourself
Old 09-24-2010, 07:06 PM
idformula's Avatar
Possibly an intake gasket, but most likely a head gasket, especially with the overheating.
Old 09-24-2010, 07:26 PM
lew10281's Avatar
Yeah im going to take it to my buddys shop so i can see which gasket it is exactly.
Old 09-24-2010, 07:30 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
The intakes are dry on these cars, meaning no fluids go through them.
The head gaskets are blown.
Old 09-25-2010, 10:42 AM
That's MISTER MODERATOR
Paul Bell's Avatar
Yeah, I'll vote head gasket.
Whatever it is, don't drive it, antifreeze in the oil will quickly lead to burned bearings/piston rings and a complete engine job.
Good time to do some nice upgrades!
Old 09-26-2010, 07:49 AM
FearLS1's Avatar
If that Firebird has a 3.8 V6 then its gonna be an easy job on replacing the intake manifold gasket. If that Firebird has the 5.7 V8 then you are
Quick Reply: '98 Firebird overheating
