Belt Squeal With A/C Off Only?
My guess is the tensioner pulley is on it's way out the door, any ideas as to why it would only squeal with the A/C off though? With the A/C on it is not there.
Its just the way the failing bearing is happening......under a little stress with it on might tighten it somehow and stop the squealing.
Take the A/C belt off, put the serpentine belt on....start it up and see if the squeak is gone. That way you're at least sure its one of the 3 pulleys for the a/c and not a serpentine belt pulley somewhere.
I bet its the lower one that is spring loaded.
