ARP head stud screws in block too far
I have an ls2 im doing heads on and my builder used studs on the two shorter bolts on each head. I ordered a new set of bolts and they didnt have the short ones so i have to reuse the studs.
For some reason, one of them screws in the block too far. I cant get enough thread for my nut.
It seems to go in hand tight to the right height, but once i screw the nut, it threads the stud in farther. Is there anything I can do? I want to get this car running asap and I dont want to have to buy two new head bolt sets.
Only thing i can think of is maybe putting oil in the block threads to hope it wont keep screwing in or possibly use a thinner washer (grade 8 from hardware store).
oh, I gotcha... I thought I was reading that funny.
Well think about it like this. The more thread on a bolt, the more surface area that bolt has to hold onto when it's torqued down. If you dont have enough thread, then you dont have enough thread contact to get a proper fasten... and I'd be nervous about doing that to something like a set of heads.
You may not want to but, if it was me, I'd just take the hit and buy the right set of head bolts.
