TCS issue
TCS issue
hey guys, I have an 01 TA WS6 M6 and the TCS button is inoperable. Is this a common problem? I cant turn the traction control off so it makes going to the track a little dull. No warm-up, no launch. Is there a common fix? Thanks guys
If the TCS works, but you can't disable it, it's probably the switch. Test by popping the switch out if the holder. do not unplug the connector. Momentarily (1/2 a second), jump the black/white wire to the brown/white wire with a paper clip. If your traction control turns off, your switch is bad.
