MAP Sensor ?
Old 10-16-2010, 06:00 PM
Rychen's Avatar
Default MAP Sensor ?
I'm in the process of changing plugs and wires and pulled the Pass side coil bank off.
I started feeling around the back of the intake and discovered the PCV & valve cover breather line rotted where the 2 lines go to 1, can that rubber thing be replaced with a Y fitting ??
Is that thing in the back of the intake with wires going to it the MAP sensor and is it supposed to feel like it's loose ??
I did a search but it didn't give me what I was looking for, can someone help me out with some answers??
01 Formula if that helps any.
Thanks in advance for your time and help.
Bill
Old 10-16-2010, 08:35 PM
Rychen's Avatar
I found that it is the MAP so I went and purchased a new one and it fits better.
If anyone knows if it's ok to use a Y fitting in place of the rotted rubber piece I would appreciate the info.
Thanks
Old 10-16-2010, 09:07 PM
bobbyd's Avatar
I also had the "Y" rotted on my pvc lines. what i did was buy 3 feet of 3/8" fuel line and ran it from the back of the drivers side heads to the the pvc line. i capped off the back of the passenger side heads/valve covers. it works like a charm an many people do this with no problems.
would be easier and cheaper.
Old 10-17-2010, 07:01 PM
Rychen's Avatar
Thanks for the tip , I did just that and everything looks nice.
man I need to get my headers on, it looks so much cleaner without all that air pump **** in the way haha.
Thanks again for the suggestion.
Old 10-17-2010, 07:47 PM
bobbyd's Avatar
no problem man glad it work
yea it does indeed look a whole lot cleaner with all that air pump and hoses removed
get the headers on there you will love the sound and the way the car feels/performs
